1 - 16 of 16 Posts
Auf Deutschland
you stupid fück
IcedC said:
There have been a lot of threads on this topic, I'm sure if you looked through them you will find a lot of useful information :)
This is what I found using the search feature
http://www.b15sentra.net/forums/search.php?searchid=43876
yea this helps them alot. "Sorry - no matches. Please try some different terms."
if you are gonna bea seach nazi do it right..lol :D
Theory freak learning...
The system in my 04' has a stock sub, but it is mounted in the rear deck. Also my deck didn't say rockford on the front. There was an extra harness that plugged into the stock deck that I believe is for that sub. Anyone got this setup working?
no **** my sub is mounted in the rear deck. There is no amp anywhere in the car either, i checked everywhere. I will post a pic later.
Super Moderator
If your sub is hanging from the rear deck on the left side, then you have the 7-speaker, 180-watt system. You won't need to do anything "special" to get your aftermarket headunit working with the factory sub, as the factory sub grabs a line-level (speaker) input from the wiring harness as it crosses the back deck on the way to the rear speakers. Built into the basket hanging below the sub is its 80-watt amp.
You will, however, not have control of the sub through any onboard subwoofer adjustments your headunit may offer.
By Any Means Necessary
When I connected my aftermarket HU to the car, my sub stopped working completely, but when I put the factory one back on, it starts working again.
1 - 16 of 16 Posts
