Non-fading pre-out is what Kenwood called the sub output. They say non-fading because that output is not affected by the FADER settings on the HU, mean if you put sound only in the front, the sub output still play.
For your Sony 4V pre-out well it might be ok just to weld 4 RCA onto a universal Nissan HU wiring harness and put your pre-out signal instead of the speaker signal (50W) going into the amp. That way you can also disable the built-in amp of the HU and this will make it less heat and play better
