Hey Guys I have an 02 Spec V with p1121 and P2135. It was gifted to me about a month ago, it is my first project car. It was in limp mode because of the codes. Since receiving it, I have replaced the throttle body, and did the relearn. Still getting the codes so the SES is still on :(. However, it is no longer in limp mode (as far as I can tell lmao), I have only driven it a handful of times. I have read that the connecter pins are none to be faulty, which can be solved with some soldering. Is there any symptoms of faulty connecter pins or should I just take it into a shop?
Some background info, I am now the second owner, it has 102k on the chassis and less than 7k on its 3rd (wince) engine. It has sat intermittently for the past 2ish years. I am good friends with the current owner and he was honest about the condition, drivers side cv axle will also need to be replaced and it has a poor quality aftermarket clutch bearing.
Any and all help would be greatly appreciated:) !
Hey,
So looks like you got a good one. Search for the repair manual on the Nico forums and check the specific definitions for each fault. Without looking deep into anything, since you already have new TB, you may have to check voltages at the ecu. Or maybe even the pedal sensor in the car maybe bad. Make sure u dont prick the harness. Get a long needle or something and probe back of the connector. Or maybe get a scan tool and read throttle and pedal,voltages and wiggle the connector. May youll get lucky and see something jump. Good luck.
  • Like
Reactions: gourab
Hey,
Hmmmm got it. I’ll look into a scan tool
I had the same problem. I changed my TB twice and it didn't fix the problem.
The problem was with the hose, specifically after the air filter. Check all the hoses after the air filter is in good condition and tightly secure all the clamps
Don't forget to go through a TB relearn process.
If this doesn´t fix your problem,
1. Check for any corrosion in the TB connector female ports. Clean it with a proper electric connection cleaner and a long needle.
2. Check your battery power and alternator.
