Sorry this is long, but I would REALLY appreciate any help. I'll send $10 to a paypal address if you can help me.
I just replaced a clutch on a 2008 2.0. I got it all together and started it up - I had no clutch pedal. This was no surprise as I hadn't bled it yet, just wanted to hear it run. It seemed to run fine.
Then I went through the horrible process of trying to bleed the new slave cylinder, I've never seen one like this and it's awful. If you're familiar with the process, you grasp the clutch line where it attaches to the slave cylinder on the front side of the transmission and move it back and forth while someone is holding down the clutch pedal, and you have a hose attached to the little nipple-bleeder on top of the clutch line and run it into a bottle of brake fluid and basically pump all the air out.
I was having difficulty with this because the slave cylinder end would move back and forth with the movement of the line. To stop this, I removed the starter and used a small metal bar through the starter hole to press against the back side of the slave cylinder to hold it still. This kinda worked and I think I got all the air out. So I put the starter back in, bolted the two wires to it, reconnected the battery and went to start it up.
It cranks but doesn't start. It sounded like it almost started, then nothing. I put a scanner in it and there are no codes. When I crank it I can see RPMs going up on the scanner so it isn't looking like a crank sensor problem. I can't find any loose,dirty grounds and I even tried a new cam sensor just for the hell of it. I put a spark tester on it, and this is odd, when I start cranking it over it sparks once then stops.
Any ideas?
Discussion Starter #2
38 views and not a single comment?
Could the timing chain have slipped? Would this not throw a code?
Discussion Starter #3
Ok, I believe I installed the flywheel incorrectly. Apparently it must be "indexed". I know most cars have the flywheel bolts patterned so it will only go on one way but I guess this one is different. I now have the trans back off and I can see a little circle between two bolt holes on the back of the crank, but I see no marks on the flywheel to indicate what needs to line up with that circle.
Discussion Starter #4 (Edited)
The flywheel wasn't the problem. The whole indexing thing is a V6 issue as far as I can tell.
82 views now and nobody even has an idea???
Discussion Starter #5
....perhaps someone could direct me to a site where people are familiar with Nissans?
Discussion Starter #6
I took the timing cover off - the timing marks were off. I replaced both timing chains, tensioners, and guides.
All fixed
...couldn't have done it without all your help!
THANKS!
