I managed(For 5 years) a Jiffy Lube while going to college part time. Man can you believe that Jiffy Lube counts towards your ASE hours. I understand what you are going thru man. When I started at the shop, the guys had this theory.
8cyl- 5qts
6cyl- 4.5 qts
4 cyl- 4 qts.
3 cyl - 3.5
AND EVERYTHING TOOK 10w30
When I replaced the shop Manager, I cleaned house. I explained to them about manufactures recommendations, quantities, and intervals. My Jiffy Lube was rock'n, happy customers, informed techs, which resulted in trusting customers.
Now here is the Catch 22. Do you want to know why they used 10W30 and used 5 Qts? Castrol Restrictions. I ran into the same basic problem with pennzoil.
I'll Explain: Every shop has to make a deal with an oil company. The price per/qt is based on amount of product estimated to be sold. If you are consistantly below the agreed amount, the price goes up.
Now for the 10W30 thing. 10W30 is the cheapest oil weight to produce, and oil companies refect that in the prices to the shops. Now the numbers that I will supply are from 1997, but calculate inflation and you'll see the difference.
This is what I paid for it:
530- .79
1030- .49
1040- .57
2050- .90
Now that may not sound like much, but when I was going through 2000 qts. every two-three weeks, the price goes up alot.
Yearly (estimated):
530- $41,900
1030- $25,480
This was probably too much information.
Food for thought: My shop used to drain extra oil that dealers overfilled. I ran into this quite often. The dealers don't always look at recommendations either.
If you are wondering how we went throught that much oil, we averaged 80 Cars on weekdays, about 120 cars on saturday, and 50 on Sunday. This shop used to bring in 85-90 K per month...
Sorry for the book.
Joe Bresloff
http://www.brez.homepage.com
Avalanch Y2K Sentra w\ Performance PAckage, 5sp.
JWT POP w\ Mandrel Intake tube. Gas Holder
92 Classic SE-R: POP, Exh, ECU, Header, TB, springs, Sway bars, Tokicos. Stillen Drilled Sport Rotors, Lines, and Metal Master Pads.
96 G20T- POP (AT)
[This message has been edited by joebrez (edited January 23, 2001).]
