Ok I got the dreaded misfire in cyl. 1 .. I had it turned off.. so its either the plug coil or hope not butterfly screw... I checked the plug .. it wasnt bent..which tells me I got lucky and its not the butterfly screw<<Hopefully.. for now I switched coil 1 with coil 3 .. to see if the misfire comes back.. and if it comes back on coil 3 then we know the problem..bad coil...my question is.. what if I dont get a light at all again?..what can it be? just a hick-up?..
ohh and the car runs fine.. I didnt even notice the misfire.. wierd thing is it happened at 11mph and at 3750rpm.. which is impossible..3750 in first is atleast 20+..weird
