Satisfied for now....
Ok I just finished wiring up my toggle switch to the fans ... I tapped into the map lights for the power source ( because of the battery saver I can have the fans run after I shut the car off for ten minutes then they turn off automatically) ran it to a 15a in line fuse then to a 20a toggle switch then I tapped into the blue and black for one fan and the green and yellow for the other fan ... they work great although not at a high speed at least they run... I will try and get pics up maybe tomorrow...
IF ANYONE TRIES THE METHOD THAT I USED DO NOT TURN THE SWITCH AND THE A/C ON AT THE SAME TIME ... I DID AND BLEW A FUSE ...
kinda scary when the locks and alarm doesnt work ...
laters MIKE
Theory freak learning...
Great! I've saw your first post about doing it too...
That thing with the A/C is normal. You see, the fan on passenger side of the radiator is the one when the A/C is running to increase the cooling. So, when you turn on the A/C, it send power to turn on this fan also. Why don't you just unplug this A/C fan completly and use only your switch instead?
