I'm having major power issues with my '01 GXE. I had codes P0171, P0174, and P0300. At idle it runs smoothly with no issues. If I floor it and hold at wide open throttle it starts to rev at first and then bogs down and holds at about 1800-2000 RPM and starts sputtering.
I replaced fuel pump and fuel pressure regulator due to the P0171 & 0174 codes with no change. I replaced MAF sensor last year so I have my doubts that it's the problem but there is always a chance it could be going bad. Both down stream 02 sensors were replaced about 2 months ago b/c of codes telling me they were bad. I'm not sure what else to try. Also replaced 1 coil a couple months ago along with new NGK Iridium plugs.
I'm at 246,000 miles and would like to at least make 300K! Any help or suggestions would be greatly appreciated!! Thanks!
