NiceGuy said:Blah, I thought the Z32 was HW6, not HW2. HW6 is the stock MAF! Oops, mixed them up.
RedVRy81 said:hmm so the z32 maf works for the new b15 se sr20 maf's?
thats not going to work with the stock ecm. a cobra maf requires a subtractor program to work with a nissan since it uses a wider voltage range. The only way to know if your proplems are maf related is to swap maf's and see if the problem goes away or data logging the maf signal to see it you are maxing out the signal at wot. since the stock maf is 70mm I would think it should be able to meter up to at least 350whp but I have not seen the voltage readings off a turbo car to gauge where the maf maxes out.RedVRy81 said:hmmm maybe i should try a different maf? cobra?
cortrim1 said:thats not going to work with the stock ecm. a cobra maf requires a subtractor program to work with a nissan since it uses a wider voltage range. The only way to know if your proplems are maf related is to swap maf's and see if the problem goes away or data logging the maf signal to see it you are maxing out the signal at wot. since the stock maf is 70mm I would think it should be able to meter up to at least 350whp but I have not seen the voltage readings off a turbo car to gauge where the maf maxes out.
RedVRy81 said:werd...what do you guys think about the ls1 maf? if you have a datalogger...ill be @ the dyno day whenever it is...free realm to whatever you want.
The Cobra MAF only requires the subtractor program if you want to use it to make over 350 whp or so. JWT can program for the Cobra MAF with or without the subtractor circuit, depending on how much power you want.cortrim1 said:thats not going to work with the stock ecm. a cobra maf requires a subtractor program to work with a nissan since it uses a wider voltage range. The only way to know if your proplems are maf related is to swap maf's and see if the problem goes away or data logging the maf signal to see it you are maxing out the signal at wot. since the stock maf is 70mm I would think it should be able to meter up to at least 350whp but I have not seen the voltage readings off a turbo car to gauge where the maf maxes out.
but this will not work with out a reprogrammed ecm and thats not availible for the qr25de.NiceGuy said:The Cobra MAF only requires the subtractor program if you want to use it to make over 350 whp or so. JWT can program for the Cobra MAF with or without the subtractor circuit, depending on how much power you want.
NiceGuy said:The Cobra MAF only requires the subtractor program if you want to use it to make over 350 whp or so. .
cortrim1 said:but this will not work with out a reprogrammed ecm and thats not availible for the qr25de.
