the updated document is here: http://www.b15u.com/general-maintenance/29264-lower-ball-joint-how.html
THIS DOCUMENT IS FRESH, USE AT YOUR OWN RISK, OR YOU WILL BE PRESSED!
last edit: 6-18-2012 at 12:42pm
i would like to thank Fullah and anyone else involved here at b15u.com for great info and influence for this write-up.
this is a lazy/cheap way to replace the ball joint on your b15 sentra without removing the control arm or any wheel hub components. I did it this way since my sentra is over 10 years old, drives daily in northern climates (salty winters), and has over 257,000 miles. so, im trying not to remove/break/strip any bolts/nuts that i dont need to.
reference for this document
oem = OEM Precision Tools Inc.-brand of ball joint press and adapters
roll of masking tape marked control arm = imaginary control arm to show placement pieces and adapters
safety and precautions
first off, please everyone make sure and be aware of what youre doing. it is always good to have a friend to help, or an experienced friend if you dont know what youre doing. you need to lift your sentra off the ground which may involve using jacks and stands, never sit/lay/poop under the vehicle, make sure the vehicle is stable before wrenching. you will also need to use a press, which involves pressing metal pieces together at very high pressures, so wear safety gloves/goggles/vests/knee pads, whatever. if youre like me, you will get angry and break out grinders and torches, use them at your own risk. do not torch or grind anything unless you know what you are doing.
what is your lower ball joint?
how much will this cost?
napa chassis ball joint - part# 260-1581 - $27 each + tax
oem ball joint press kit - oem#27023 - $100 + tax, rental - full refund on return
total: $27 + tax + additional fluids or tools you dont have.
what are the specifications for your lower ball joint?
what are the tools i need to perform a ball joint replacement?
once you have your ball joints, you will need this ball joint press and the adapters. the cone adapter set oem#27163 will makes things 50x easier if youre pressing by yourself, but is not necessary. you will also need the basic tools in the pic below which includes a 22mm hand wrench.
do i need any additional tools?
A BETTER SNAPRING TOOL
2+ ton jack
2+ jack stands
2 wheel chokes
some 2x4s
wheel lug wrench
getting started:
1-park your car with room to work and apply ebrake and wheel choke
2-break loose wheel lugs and jack up the sentra
3-if necessary, carefully jack it up as high as your stands will go safely (at least one slot down from highest) and take the wheels off
4-identify your ball joint between the wheel hub and control arm, if its not within specifications, it will need to be replaced. otherwise stop here. while youre here, make sure to check the control arm bushings, mine were good so i did not replace them, you can get new bushings or the whole control arm with bushings and ball joint already. if you buy a new control arm and it comes with a ball joint, you dont need to press your ball joint, just swap the control arms.
5-there is a cotter pin/lockpin on the top of the ball joint, above the nut that prevents the nut from loosening. remove the cotter pin by bending it straight and pulling it out. if it doesnt come out, try to tap with small hammer and screwdriver or allen key, else drill it out, the cotter pin is very soft metal.
6-spray pb blaster on ball joint nut and threads, allow it to penetrate. this will be difficult use a torch if you know how to use it before you round the nut. now you need to loosen that nut on the top of the ball joint. it uses a 22mm wrench. there is very little room, i used a regular hand wrench with other close-ended wrenches for leverage. MAKE SURE YOURE LOOSENING THE NUT, not turning the threads or base of ball joint. IF YOU CAN NOT REMOVE THE NUT, DO NOT PROCEED FURTHER, seek a mechanic or other professional help. my right side was locked on and torch did nothing, so i broke out the grinder.
tip - from fullah - "One tip I do have is if the ball joint is really worn out, it will sometimes keep spinning when you try to loosen the nut. Basically the nut and the ball joint itself are both turning. What you do is place your jack under the ball joint and lift the jack to apply pressure to the ball joint. This will keep the ball joint from spinning and allow you to remove the nut."
7-once you got the ball joint nut off, the next step is to remove the snap ring. if it looked like mine, you ended up using a small flathead. you can also use the press to press in the ball joint more, it may expose the snap ring more.
8-you will need to disconnect the sway bar end from the control arm. you will need a 14mm socket for the nut and 12mm open-end wrench for topside.
9-use a mallet or pry bar to break loose the ball joint from the hub. use the pry bar to hold the control arm down enough for you to work the press.
2+ ton jack
2+ jack stands
2 wheel chokes
some 2x4s
wheel lug wrench
getting started:
