Hi, guys. So I've had a P0171 for as long as I can remember. I got an aftermarket MAF from ebay, and the car would idle at low RPMs, stall, and had zero power. I reinstalled the old one and the car worked fine, save for the P0171.
I decided to try this again and found another MAF on ebay. The idle went from ~800 to ~1100 and got a power boost BUT the car would stall in neutral and halved my mileage (17 mpg highway isn't working for me!). Put the old one back in back but I have near zero acceleration.
TL;DR: Cheap MAFs suck
SO I'm done with the crappy MAFs and I see you guys recommend a genuine part for the MAF. Where do you recommend I find one? Thanks!
you don't specify which engine, and what year. that makes a difference. I have had good luck with Rock Auto. I would NEVER EVER EVER buy parts on ebay. Also, how do youknow it is the right part number? If there is a problem with it, then where do you go? the seller has your money... at Rock Auto, you can return it if it is bad.
