1 - 11 of 11 Posts
I've had it relocated for a year or so now and I feel like some timing is being pulled. It might just be my mind but is there any way to check if the sensor is grounded so that I know i'm not losing hp?
Boost Addict
you would need to check the ecm with a consult II all k/s activity is logged.
Boost Addict
Bobby Digital said:
if it's not grouded properly would it throw any kind of code in the ecu that i could check with the gas pedal diagnostics?
k/s activity does not throw a code that can be checked with out a consult II. recheck your connections if they are still solid you may be feeling a loss due to increased temps because its summer. Hot air is less dense than cold air ;)
Immature Tough Guy
Since I don't have regular access to a consult2 (unlike Mike who's good friends with a dealer...lucky bastard), a couple of times a year I will remove the insulation around the relocated KS and just check to see if I'm getting a ground signal with a volt meter.
Also, Mike's right about the weather...it's unreal how much stronger the car runs at night vs hot humid daytime driving.
If your knock sensor is not grounded correctly, you WILL throw a code, (either knock sensor voltage too high or low...not sure). However it's not a code that lights up the SES light. You have to get an OBDII code reader to pick it up.
Discussion Starter · #8 ·
yeah this is what i was thinking....i checked it a while back and got a code for knock sensor high voltage. This is also when my cam position sensor went out and threw a code too. I havent checked since i got everything fixed. I'll check it out today and see if there is a code. Hopefully not b/c that KS was a pain in the ***.
Boost Addict
you can always reground the k/s. I always ground it back to the block in the stock location. this way you can reuse the stock bolt with the aid of some washers.
Boost Addict
as a side note if you check the wire with a multimeter the resistance should be .3 ohms or less for a good ground point.
Discussion Starter · #11 · (Edited)
alright thanks for that heads up. I check everything out yesterday when i changed my oil and things looked OK. The eyelid was still screwed into the block and ran into the rag that I have wrapped around the censor. I'm going to check for codes now.
1 - 11 of 11 Posts
