2003 SpecV, ~115k miles. I bought the car with 114k on it, did an oil change, air filter, and replaced my crank angle and crank position sensors within the first 200 miles I owned it (after experiencing the "tachometer dropping to 0 while running" problem twice).
Car runs fine 99% of the time. I do have the prime the fuel pump (turn the ignition to 'on' for a few seconds, hear the pump whine to life, then start the car) otherwise it takes a bit to crank over.
The real problem is that occasionally it will misfire for a few seconds (5-45). This can happen right when the vehicle is started, it can happen at a stop light, and once it happened while I was on the highway.
Sometimes when I start it (seems to be exclusive to when the motor is already warm) I can smell fuel, very strongly, and then the car will start into the misfiring.
The biggest problem is that when it's misfiring, it may or may not trigger the SES light. When it does trigger the light, it's flashing (which I know means stop driving the car immediately), but once the misfire is over, or if I start the car after turning it off, the problem is gone and the light is off.
I remembered that the car had an aftermarket warranty and took it to a Nissan dealer explaining the problem. They have had a ***** of a time recreating the problem. They were eventually able to pull a "General Misfire" code, but other than that they have not been able to experience the fuel smell, or repeated misfiring.
I'm beyond frustrated at the situation, and this is the second time the Dealer has had the car. They know about and have checked my work on the sensors. I'm about to pull the trigger on this, just to see if it will help me collect enough data for them to know how to approach the problem. I've already surrendered the car to them for the rest of the holiday week, encouraging someone at the dealership to drive it as a personal car with their own logger plugged in.
Has anyone experienced this problem before, and/or can anyone point me in the direction of a reasonable ODBII logger to help me figure out what the hell is wrong?
