I've searched throughout the archives but have only found bits and pieces. I don't know about you guys but is the instrument panel lighting dim in your XE (even with dimmer at max lighting)?
I bought some blue "superbright" 12V LED from eBay but the same problem persists. Still dim and dull and the LED doesn't illuminate the entire panel. Are there other lights hidden elsewhere? Even the odometer screen looked blue and couldn't read the mileage from it. It looked nothing like the others who posted their nice bright panels.
I've also read about taking the cluster apart (including removing the needles) and sanding off certain parts (not sure which). I got to this part but found that removing the speedometer needle quite difficult. it budged but I wasn't able to fully remove it so I snapped it back to its original position. Now it doesn't work.
I apologize for being long winded but I want to make sure i'm as clear as possible on the issue(s) at hand.
So...how do I fix:
a. the lack of lighting in the instrument panel?
b. the stuck speedometer needle (I still would like to remove them and work on the back end to make the panel brighter)
Thanks again
So...how do I fix:
Thanks again
