Yeah it comes with no stock shway bar so yeah.
1. take off wheelz
2. unscrew rear motor mount cross-bolt. 14mm
3. unscrew rear motor mount sub-frame bolts. 17mm
4. partially unscrew front motor mount sub-frame bolts. Leave them still screwed in, dont pull em off too much. 17mm
5. Yank rear MM off the mount and let it hang down.
6. Remove cotter pin from Tie Rod end. pliers.
7. Unscrew Tie Rod Nuts. 14mm
8. Detach Tie Rod Ends. Use Ball Joint Separator and Hammer.
9. Remove Rubber grommets from FSB.
10. Work the FSB into position somehow. LOL.
11. Replace rubber grommets back on FSB and place brackets on them, screw all the bolts down lightly. Then proceed to screw them all down completely.
12. Place Sway Bar Endlinks in place and screw lightly to control arm.
13. Screw Sway Bar endlinks onto FSB and screw everything down nice and tight.
14. Reattach all the stuff you took off and youre done.
Some pics of when i was done.
Notes:
My car didnt come with a FSB so i had to buy
- Endlinks (54618-4z000)
- Brackets(54614-4m700)
I also had to buy the Endlink bushings but i bought the Energy Suspension Polyurethanes instead of stock rubbers why not right?
-ES bushings (98106G)
Also had to purchase:
- Nuts for the endlinks which were M10-1.25 size.
- Bolts for the brackets which were M10-1.25 x 40MM
I bought all class 8.8 S.S. from Home Depot.
1. take off wheelz
Notes:
