I have a 4 channel US Acoustics USX-4065. Ive had it since May. I was listening to my music and all of a sudden the music got lower. I realized that there was no more music coming out of my rear right speaker. I did some troubleshooting. This is what I did. I pulled out the fuses and they looks to be fine. I switched them and put in one at a time in each slot and the everything was still working so I assume the fuses are ok. I switched the channel 3 speaker output with the channel 4 speaker output and now my left rear speaker wasnt working and my right one was. SO therefore I assume my amp broke. Now I gotta search to see if I have a warranty but even if I do itll probably take weeks to fix. Is there anything else Im forgetting to check or am I right to assume that one of the rear channel outputs isnt working?
Discussion Starter #5
What do you guys think? Buy a new amp (Rockford Fosgate Punch 501X) or just replace this one under warranty?
if you can get it replaced under warranty, then obviously do that, even if you are going to buy a new amp...
