I need some from experience advice on a single mass flywheel.. I'm about to do an engine swap and want to get rid of the stock flywheel, I'm open to suggestions/ opinions.. and also opinions on the JWT Balance shaft removal kit..
Thx:D
GKit
assuming youre mechanically capable to do this work, the jwt bsr is a great mod, just a pain with all the rtv everywhere, so take your time and do it right the first time. as for the fly, if you keep it over 14lbs, youll may only have minor stalling issues, under 14lbs on stock ecu will have idling problems even with a raised idle. if youre doing a fly, a clutch job isnt a bad idea since youll be in there already.
