41 - 60 of 61 Posts
where can i find out what other codes mean because my car gave me the code 0420 and i didn't find it on the list and i looked in the horrible owners manual for anything and got nothing??
Discussion Starter · #42 ·
P0420 (Bank 1)
P0430 (Bank 2)
 Three way catalyst does not operate properly.
Check Items (Possible Cause)
 Three way catalyst
 Exhaust tube
 Intake air leaks
 Injectors
 Injector leaks
 Spark plug
 Improper ignition timing
Discussion Starter · #43 ·
NightKids said:
hey everyone so my ses light came on today and the code was
H02S1 HTR (B1).....0031 can anyone tell me what it is exactly thanks
The current amperage in the heated oxygen
sensor 1 heater circuit is out of the normal
range.
(An excessively low voltage signal is sent to
ECM through the heated oxygen sensor 1
heater.)
 Harness or connectors
(The heated oxygen sensor 1 heater circuit is
open or shorted.)
 Heater oxygen sensor 1 heater
SpecVcepS said:
anyone find this thread helpful, or was it just a waste of my time?
Helpful is an extreme understatement.
Thankyou for this Post.
You the man ! :D
FYI........................FYI............................FYI
if the SRS light is on it could be cause you primed the SRS system which means that 1 of the 2 stages of airbag deployment has been activated so just hitting the breaks to hard, bumping the car, etc. could set them off usually though if it will send another code after you reset it so if the SRS light keeps coming back I'd get it checked and it means getting one or both new air bags
It's just not... working
I have an '02 spec with an '03 QR25DE (kept the '02 ECU though) and I tried it a bunch of times with and without a watch and couldn't get it to work. I never see the MIL light flashing. Although my idle is pretty high, so I'll see if it can be fixed in the same manner as Oktober.
And is there a way to reset the SES light without being in diagnostic mode?
What does it mean to be in Diagnostic Test Mode II?
I've completed all the steps up until I want to clear the codes. Everything is flashing, but I am unable to turn the ligh off by holding the pedal down and releasing.
This is a GXE, am I just unable to not clear the codes, only read them?
· Theory freak learning...
Watch out with a GXE if the procedure involve gas pedal, you will flood the engine :eek:
Been having a terrible time trying to reset my abs, on the data link when I go to erase codes, do I ground terminal 9 to terminal 1 three times? I'm using a stop watch so I'm under 12.5 seconds, each ground is more than 1 second, doors shut, radio off, lights off. Not sure what I'm doing wrong.
41 - 60 of 61 Posts
