Weirdly enough the compressor comeing on with the defrost was my biggest anoyance. So thank you very very much
i have somewhat of a similar problemplacenta said:did it. but i used the snip and tie method. I will never want this feature back. Works fine, and now i can use the A/C for defrost only when i feel like it.
my damn knob doesnt turn all the way to defrost, kinda fights the cable.. didnt figure anything out yet, tried to fix it while i had it apart.. from the looks, it appears to be on the other end of the cable sticking, not the switch end of the cable.. ill do a search and see if others have this.
NTB03005
IF YOU CONFIRM A 2002 or 2003 Sentra has any of the following symptoms: · Air flow amount is different between the left and right side of the center AC/Heater vents · "Flapping" noise from the center AC/Heater vents · Temperature Control (Air Mix) Knob is stuck · Temperature Control (Air Mix) Knob turns freely but will not change the temperature · Mode Control Knob is stuck Refer to this bulletin for detail information.
lol i had a whole post about this, its this foam stuck in the vents so it doesn't blow directly in your eye, its normal though, u can always have them rip it out if it bothers u... not a bad idea too memetalhead said:ok
i got my car back
Tom at the dealer confirmed the problem, and said i need a new heater control box, or something of that nature...they didnt have the part in stock, so im gettin a call when they do and itll be fixed....i forgot to tell them also that my left center vent doesnt blow out much air, less than the right one, and thats another sypmtom, but im sure it will be fixed also.....should i mention this to them b4 i take it in next time?
