I doubt it.adc100 said:I knew this was a noob as as soon as I saw the post title
Do you know the difference between a turbo and supercharger?
8psi is safe on stock internals on a spec v. as long as you have the car tuned. and it's more like a 75-100hp gain... unless he has a QGsentra001 said:Its pointless to put on a turbocharger without doing the internals. Ricers are the ones that throw on turbos onto a stock Naturally Aspirated engines and blow them up. If you do put on a turbo onto a stock engine with stock internals, then I wouldn't run anything higher than 6 psi. So why spend $3000.00 on a turbo kit for only a 25 Hp gain.....if that.
LOL! "25 hp" increase on a turbo'd QG!?! NEVAR!!!jarrett2k said:8psi is safe on stock internals on a spec v. as long as you have the car tuned. and it's more like a 75-100hp gain... unless he has a QG
8 psi equals 75 - 100 whp?........Really? Not to be argumentive, but that sounds unreasonable.jarrett2k said:8psi is safe on stock internals on a spec v. as long as you have the car tuned. and it's more like a 75-100hp gain... unless he has a QG
It's plausible, I believe Big J with the treadstone kit was somewhere near 300 whp with 7 or 8 psi.sentra001 said:8 psi equals 75 - 100 whp?........Really? Not to be argumentive, but that sounds unreasonable.
hmmmm, why not???StreetUnionWynd said:LOL! "25 hp" increase on a turbo'd QG!?! NEVAR!!!
Tuning.sentra001 said:8 psi equals 75 - 100 whp?........Really? Not to be argumentive, but that sounds unreasonable.
Haha I was being sarcastic, and as a fellow QG owner I wasn't ragging on the QGtek1255 said:hmmmm, why not???
Actually you can get up to 400+ on 6psi with the sentra, with cometic head gasket and arp head studies u can put it up to 8psi and make even more than that, not a ricer, simply a budget buildIts pointless to put on a turbocharger without doing the internals. Ricers are the ones that throw on turbos onto a stock Naturally Aspirated engines and blow them up. If you do put on a turbo onto a stock engine with stock internals, then I wouldn't run anything higher than 6 psi. So why spend $3000.00 on a turbo kit for only a 25 Hp gain.....if that.
