The horn on my 2001 GXE doesn't work. I checked the horn, fuse, relay, wiring and found that the problem is between the fuse and the relay. However, it's not that the wire is broken, but there is a drop from 12 volts on the output of the fuse to 2.57 volts on the relay input. Any ideas where does the resistance come from? What could have gone wrong?
Discussion Starter · #2 ·
Does anyone now how to pull out the harness on which the horn relay sits? I pushed on the tab to release it, but it would not come out. It seems there's something holding it on the bottom.
Thanks a bunch. The dealer wanted $190 to fix it and the car is out of warrenty and I was not going to pay that much to get it fixed. The only reason I even had it there is because the sunroof broke, it would no longer close on it's own. That hurt seening it was on my dime.
