I have had a 2001 Sentra SE for about four years now. Never really thought about joining a forum until recently when my car started acting with something i cant seem to fix.
I had origianlly asked what was wrong on another forum but didnt many response. One person over was helping me out. I appreciate his help but still having problems. So i figured try a B15 site. So here i am.
I hope you guys dont mind helping me. Here are my symptoms and what i did. Its gonna be long but i will try to break it up so that your eyes dont get tired. lol. THANKS!!!!
One morning while driving i noticed almost no power/acceleration, It would hesitate as the rpms climbed. More like jitter as the rpms climbed. Its fine in neutral, both idling and reving. There was always a check engine light on, Had issues getting rid of it.
After a painful drive home, I borrowed my friends scanner, Got 4 codes. p0171(system to lean) p0325(knock sensor malfunction) po733(3rd gear ratio) p0134(o2 circuit no activity). I cleared the codes. The p0325(knock sensor code came right back).
Next morning i had to painfuly drive it to work. Down the block. After getting home i ran the scanner again to see if anything new showed up, At this point my light was still off. Scanner read no codes at all. I was told to check the cat by putting my hand on the exaust to see if there was flowing exaust and that the exaust wasnt to hot, Seemed fine, Was able to keep my hand there without burning it. That is where im at.
On a side note the problem seemed to get better as it warmed up, Didnt go away but was able to get through the gears easier after warming up, Any advice would be apreciated.
I disconnected the o2 on the Manifold, Getting same problem, maybe even a little bit worse then before. Did not trigger a light.
Light finally came back on. Got three codes. A p0135(02 code) and 2 about the gear ratio. But i was told that a bad 02 doesnt cause these type of problems.
replaced the upper 02. Stalled first drive after. Has never done that prior. After restart car seemed to get alot better not 100% but alot better. Still slugish. This morning from a cold start acted as if no part was replaced and went back to old symptoms. Should i try the maf next?
So you made it to the bottom. I appreciate the read. THANKS!!!
