1 - 7 of 7 Posts
wtf! here's the deal, i made an adapter plate to mount the six speed to an sr20. that works just fine. the thing that wasn't was the flywheel wasn't out far enough to put the trans shaft into clutch disc. so i had a new custom flywheel made and inch thicker. that all worked out good but the f'n bolts that hold the flywheel on needed to be an inch longer. sounds simple huh? HELL NO! there 11mm with a 1.0 thread and they needed to be 50mm long. i serched high and low and nobody makes them! i called ARP and they said 800 dollars for 8 f'n bolts! if anyone knows were to get them please help.
WOW!! $100 a bolt?? That's some crazy stuff, man!! Why don't you try searching for a shop that sells fasteners. They usually have everything under the sun, and then some. Make sure you order Grade 8 or better, cause them bolts are gonna take a pretty good beating.
1 - 7 of 7 Posts
