I am in need of help. I have a 2001 Sentra SE with disc brakes all around. My rear brakes were making an awful sound. So decided to inspectect them. as I began to remove the calliper, I the piston came lose in my hand. then brake fluid started to pour out. The rubber boot had come loose. I tried to screw the piston back on, but the adjust nut(#29 on pg. 23 of fsm. in Section F, Brakes, Brake System) inside the piston spins. I tried putting a pin through a small hole on the side, near the top of the piston. But that didn't seem to do anything. Any ideas and or suggestions would be greatly appreciated.
I will end up going to a dealership tomorrow to see how much a new set of calipers will set me back.
http://www.southern-shift.com/sentra/br.pdf
