I plan on hooking up an amp using seaker level inputs and really want to tap the factory amp turn-on lead but need to know which one it is...is there any way of getting the wiring diagram or does anyone know what each wire is?
There are 2 wires on that amp harness. One is constant 12 volts the is the turn-on lead. I think the turn lead might be the blue(maybe blue/white)wire. I did that setup with my amp but can't remember which wire it is. If you have a volt meter, you can test the wires to see which one has 12 volts only when the radio is on.
P.S. I will look after work and see which wire it is to save you some trouble, or maybe someone else can see what it is.:cool:
