Hello sentreros. as you will see I am new around here. and I'm looking for help to do my first swap. acquired a sentra b15. with broken engine and transmission. and I want to increase its power by installing a vq30de. I've been researching and it doesn't seem that complicated. someone to guide me in the modifications I have to make
You're going to need first off, a Spec-V trans or a vq trans, custom driveshafts, a wiring harness, an ecu, engine mounts, and a custom fab exhaust and that's just a start. You need to match as close as you can to the Altima mounting points and perhaps cut the firewall to make it fit.
I'm beginning accomplishing some prep work. Taken out the hood, a 12mm attachment wrench gets the job done eliminating the hood from the pivots. 12mm for the hood swaggers too. Stillen front lip tipped the scales at 4 lbs. very little weight there, a weekend ago I eliminated the back spoiler off the storage compartment to check whether it merited eliminating (weight decrease) for racing yet it likewise just gauged 4 lbs.
Tutuapp 9Apps Showbox
