I am doing an auto to manual swap. I couldn't get the driver side drive shaft back onto the tranny. I think the circlip is acting up, does anyone have any good ideas in getting that thing on?
Thanks
Matt
Thanks
Matt
would it be wrong to use this as my sig. It's greatdavid said:The easiest way is you get it pushed int a little bit. Then you push hard and quick from the end inwards. You may have to do this a few times for it to seat itself in. It won't seat without using some force.
Simply pushing won't do it though. It has to be a quick action.
SR20dee said:couldnt you use like a mallet or hammer or something to impact it in?
i know from experiance that getting the drive shaft back in takes force.
KICK *** MATT said:I tried that too, I am starting to think/suspect that the manual/auto drive shaft is different.
david said:Well that just would have to do with the length. The spline design is usually the same.
