1 - 18 of 18 Posts
Powered by Honda
Ok, so I was driving home last night, and my engine just dies on me when im at idle at a stop light. (clutch out, out of gear) then at the very next light it does it again. (clutch in this time, in gear). I drove on the highway for awhile, ran it up high on the tach, got the secondaries open, and it was fine until I stopped the car. I parked it at a friends house for 20-30mins, got back in, and it did it again, once when I was pulling over, once when I was trying to back up. WTF is happening here?! No SES light on, its just dying. Im about 500KMs from my 56,000KM service, so perhaps it just needs a tune up? I just put gas in it, perhaps the fuel was bad? A couple days ago I was driving around with the Fuel low light on for about 20-30mins, cause I couldn't stop for gas. (perhaps I picked up some crap from the bottom of the tank and now its clogging the injectors?) What should I do? I have a custom pop charger intake, which has been on for about 2 weeks, with no problems. Im running a K&N filter, and 89 octane gas. Maybe I should run a tank of 94 and some injector cleaner? has anyone else ever heard of this problem? I did a search and found nothing.
Check for a vac leak. Check all your vac lines. Make sure your Pop Intake is on tight. Check overall condition of your engine bay. Make sure everything is bolted down tight. Check battery connection. Check oil too.
Shane
Southern Shift Racing
Shane
Yeah, check those...but it also could be your CPS (crank position sensor) or your ECU on its way out.
Endless USA S13 Silvia
this had happened to me.....didn't throw any codes but the pending code was the camshaft position sensor.....replaced it and problem went away......however now the problem seems to be creaping back up on me......sooooo.....going to have to check the pending codes again and see what it says......i'm not worried though.....only does every once in a while.....that's how it starts and it just gets worse from there...anyway.....have your car checked for pending codes and see what it says
Late,
Daniel
My car is doing the same thing..sometimes it wont do it at all then other times it does it at every light..it scares the heck out of me and i have no clue what it is either..
Powered by Honda
Shane
Pop intake is indeed on tight. Where are the vac lines? Sorry, im not exactly a mechanic. Oil is getting a bit dirty, because its near time for a change, but there is still lots of it in there. How do I check the pending codes, is it the same as with when the ses light is on, i do the 'diagnostic' procedure as described in the sticky at the top of this forum?
Did you have the crank position recall done on your car?
Those are the exact symptoms that Nissan Corporate gave us to watch for
on stalled cars...
Powered by Honda
Discussion Starter · #8 ·
on stalled cars...
Im not sure, I bought the car used from a Nissan dealer, so I would assume so. I also stumbled accross this service bulletin:
# date description
01-074A MAR 02 Engine - Dies at Idle/Stumbles/MIL ON/DTC P0340 Set
I have everything except MIL ON, should I take it to the dealer? and should i put my intake back to stock?
If you want you could, I always think people should before they hit our place for warranty work... These tech's get a lower pay rate when working with warranty stuff, so the ALWAYS look for something to blame the customer because then they get more money.
All you have to do is call your local dealer, ask for the service department, tell them you want your VIN number ran on service comm (have your vin ready) and for them to check for any out standing warranty campaigns....
i've been told that my car isn't covered under the recall :rolleyes: last time i was told this my engine died and then they extended the engine recall the week later :mad: stupid ***cing Nissan Corporate.....anyway......in order to check for pending codes you need a scan tool of some kind........whether it be a generic one or the Consult II that Nissan uses.....you don't throw a MIL light for pending codes b/c they are not enough of an issue to cause any type of serious problems......i just replaced my camshaft position sensor myself......takes all of 3 seconds......maybe 7 if you're not mechanically inclined.......i haven't tackled the crankshaft position sensor yet.....just too lazy i guess......maybe i'll do it next weekend.......please keep us posted on your progress though
Late,
Daniel
creating HAVOK
check your battery sounds like what happen to me b4, my terminals were all corroded and then my battery gave out 6 months later
Powered by Honda
Discussion Starter · #13 · (Edited)
Well I reset my ECU, didnt do anything. My stupid damn thing keeps stalling! And its not a violent stall at all, it is so quiet and smooth that i dont even know thats its not running until I see all the lights on. Its even quieter and smoother than if i were turning the key off.
I checked with Nissan, and all the recalls have been done.
yup......i had the same problem.......it was throwing a pending code for the cam position sensor......replaced it and everything was cool........you really just need to find out what the pending code is if there are any
Late,
Daniel
You really should take that thing in, they have a real problem with ECU's as well.
Before you goto merge into a busy lane and it quits and you get a assfull of another car..
Powered by Honda
Discussion Starter · #16 ·
Ya, its going in tomorrow morning. Someone I was talking to locally said that they had a simmilar problem, of idling really low (their car never actually stalled out) but they had their fuel resonator (or regulator, im not sure which) replaced and the problem has not come back since. So, I guess I'll get them to look at that as well.
this happend to me 2 but it was my ecu. there were days when it started up again but one day it stopped starting up again completely. wasnt gonna warranty because of my mods too.
Rotary GURU
Dirty Throttle Body
I just developed this problem, and solved it tonight.
The throttle body normally allows air around the throttle plate when fully closed (at idle).
The throttle body was FILTY FILTHY. There was dirt on the plate, and around the border of the throttle plate. So much that I couldn't see past it, i.e. how could air flow around it.
I cleaned it with some brake cleaner and it idles perfectly, doesn't dip when coasting and does not stall.
I have the exact same K&N filter on my RX-7 (albeit 2 of them) and the throttle body has never gotten dirty at all, despite 3 times the mileage. :( something fishy is going on with this damn filter on the Spec :(
Oh well.
Anyways, hope it helps.
1 - 18 of 18 Posts
