I have a 2001 nissan sentra I have an issue with the rp m's going up and down sporadically when try to accelerate I have replaced the engine wiring harness idle air control valve the coolant sensors the egr temperature sensor the the throttle position sensor and still nothing when I bought the car it had an idle air control valve code we found that it had high resistance in the wiring harness so I purchased a new 1 still when you press throttle the tack jumps up to 2000 rpm's and down sporadically????????
