It previously had the fuel pump and the filter replaced and the starter.I found the dtc- p0110 after putting the ecu in diagnostic mode.
I am also not getting fuel in the throat.It is getting to the engine.Got a weird noise as I try to crank it.Bad IAT switch? I am not sure.How about the O2 sensors?
I don't know if i can fix it myself.Should I buy a diagnostic tool nissan consult 4 suggest by my friend?
P0110 NISSAN - Intake Air Temperature Sensor Signal Range/Performance
not sure what you mean by no fuel in the throat? whered you t the fuel line? remember there are fuel pressure issues that are common in sentras. normally you have to prime your fuel. what weird noise do you hear when you try to crank the motor?
replace your iat sensor, on some models the iat is built into either the maf or tb, if thats the case, try cleaning them before you get a new one. USE ONLY CNC MAF CLEANER FOR MAF!!! remember to disconnect the battery before you disconnect the maf. and do the 3 relearns afterwards.
