did you empty out your fuel tank from all that bad gas? bad gas will give you that stalling problem. otherwise, how is it stalling? when you startup, does it idle? or just drop dead? does it only stall when you drive? etc? really you need some codes, but dont forget to check your battery terminals for tightness and good ground contact, check your battery voltage motor on & off?
