1 - 12 of 12 Posts
Headers for 01' Sentra SE Where do i get them and whats a decent price and better make?
ok i am not sure about the SE headers.......but i think Hotshot is the only one makes them......correct me if i am wrong...
and do a search first next time.....or you will prolly get flamed....:p
Check out Evolution Racing (the link is the banner at the top of this page). They have the Hotshot header for $460. That's a really good price.
It gives really good gains. Darkside SE dynoed his 2000 SE and gained about 9hp with just the header.
Both Stillen and Hotshot have a B14 application, not for 2000+ yet. With little modification, both B14 models can be installed in our cars. I'm waiting for awile, but I'll probably end up getting Hotshot next May.
Dont compromise. Get the Hotshot. It gets better gains *across* the band. And it has higher peak numbers.
Go to:
www.se-r.net
They have dyno charts. Personally, I have the Hotshot and it was worth every penny.
As far as I can tell, though, you cant lose with the Stillen. It makes power at different parts of the powerband (I think low to midrange). 2-4 hp isn't enough to really discern.
DONT go with the Pacesetter or any other knock-off.
There is also a couple other brands, but the Hotshot and Stillen, other than good power gains, have quality flexpipes (important). The Stillen doesn't require a gasket between the primary and secondaries. The Hotshot comes with a *bulletproof* copper gasket.
All other brands include some kind of paper gasket that'll last *literally* a week or two before they blow out.
Fogey
Hotshot has one specific to the b15. It adds a hanger to the secondary and they should be throwing in another o2 bung so you can not get a check engine light.
And yes this has all be discussed before.
Discussion Starter · #9 ·
Ok im gonna go with the Hotshot but I cant find it anywhere what site can i go to to order it??? the only ones i can find are for the B14 is this the one that can be slightliy modified to fit?
Fogey
try http://www.importpartsplus.com
There is a ad at the top that says free shipping, if you click on that it will bring you to his site.
William will be able to order you the b15 headers from hotshot.
Chesse Curd Connoisseur
Just a quickie.....
If you use the "B15" header from them, you still have to toss the closed-coupled cat., don't you?
tusk said:
Just a quickie.....
the closed-couple cat is part of the headers, so to ur answer, its yes
1 - 12 of 12 Posts
