1 - 20 of 35 Posts
Has anyone ever installed these GC Casmber/Caster Plate adapters they sell with their Advanced Design suspension system on a B15 Sentra. We finally got our suspension after 16 weeks, but no one there has any pics or instructions on where exactly to weld these puppies in. Anyone with pics or who has gone through this exercise please let me know.
[email protected].
Many thanks in advance.
Fogey
I didn't know GC was even selling C/C plates. Do you have any pictures of the setup. I can probably help if I see how they have them setup.
Actually they're pretty trick. The adapter plates weld onto the top of the shock tower, but I haven't been able to get anyone at GC, even the designer, to get me an installation page or pictures.
As soon as we get it figured out, I'll post some pics on our site.
You trim the plate that they supply, mark out the camber plate area, cut out the top of the shock tower and then weld in the adapter and mount the caster camber plates. We did it last year on a World Challenge car we built. We didn't use the adapters then, we just cut and reinforced the shock tower. The new way looks a lot stronger for the road racing we'll be doing. I'll post pics as we do the installation.
With the new setup you can get about 5 - 6 degrees of neg camber.
I haven't had my car on the track (just autocrosses) since I had the tower slotted, I'm hoping it will hold well. Although, the mechanic that did it for me is my dad's mechanic and builds Porsche racecars for a living. I asked him about crash bolts and he said, "not for a son of a long time customer like your dad, if we are going to do it, we're going to do it right."
Discussion Starter · #8 ·
I'm surprised the mechanic would say that after slotting the shock tower. The bolts can come loose and the strut can slid outward. I've seen it happen many times. Never slot a bolt hole. We drilled holes 1/2 inch inboard and mounted the strut there and then we used "crash" bolts for an additional 1.5 degrees of neg camber for a total of 3 degrees. We race consistently on this set up and have never had a problem.
Immature Tough Guy
I also thought about enlarging the three top strut tower bolt holes, but there are several factors that made me keep it stock:
-> Once you enlarge the holes, there's no going back. Unlike the bottom two strut holes, where you can just get another strut housing if you want the holes back to stock or use crash bolts to begin with.
-> The three upper bolts only require 20 ft/lbs of torque and the strut tower metal is a little too thin for my taste. Conversely, the bottom two bolts need 90 ft/lbs of torque, and the construction of the metal around the two holes is much thicker/stronger.
-> Altering the center strut tower clearance hole is illegal for SCCA STS class autox competition. And it's not exactly a modification that can be hidden easily.
That's not to say I don't have an interest in these GC plates, I really want to see pics and how much they cost. When my car is off road use only in a couple of years I would probably get these and try to get 3-4 degrees of negative camber. I really like the idea of welding an adaptor plate to increase the strength of the strut tower.
One more thing, in terms of caster, do these GC plates allow the top of the strut to be leaning more toward the rear of car to allow more positive caster? This may noticable improve our lackluster steering mechanism by possibly increase steering effort as well as improving straightline tracking.
hmmmmm... interesting... me want...
david said:
Have you ever seen castor/camber plates before? What would be the point if they were not adjustable?
A simple question is all it was. No I havent seen them before. Follow your own rules, david.
:rolleyes:
1 - 20 of 35 Posts
