what's a "fule injector"?
There is no fuel filter on the outside of the car.. The QR has a fuel filter built into the fuel pump canister, inside of the tank. There is a hard line that comes up to the front.. and then a nylon/rubber coated hose that goes from there to the fuel rail. There is no fuel return line on the QR either. If you are trying to put nitrous on your car.. which I suspect is why you posted this... You will need to cut out that nylon/rubber hose, and replace it with Goodyear fuel injection hose.. Put a brass T in that line, and then run from the T up to your fuel solenoid.
Travis
