1 - 1 of 1 Posts
We are selling a Brand New turbo kit less: turbo, wastegate, BOV and intercooler. This kit has never been installed and is a complete less the hard parts.
:: SPEC-V STAGE II Kit Includes:
- Oil Feed and Return Lines
- All flanges and bolt hardware
- Greddy or Nissport Oil Adapter (pre tapped for 1/8" NPT)
- Water Feed and Return Lines
- Clamps and Adapters for upper and lower rad hose (*For GT2871R Upgrade only)
- Coated 2.5" J-tube, gaskets and bolts
- 2.5" or 3" Mid pipe w/ flex tube
- Coated Protech hi-velocity manifold
- All Aluminum Intercooler Piping w/BOV flange Black Crinkle finish
- All silicone couplers and T-bolt clamps Red couplers
- Bosch BOV with Recirculation Hose
- 3" Aluminum Turbo Inlet Pipe w/hose adapters, MAF adapter and hardware
- 3" hi-flow Air fFilter
- Hi-flow fuel filter
- 446cc injectors (Flow Balanced)
- Injector Harness w/heat shrink and solder
- Inline fuel gauge with fitting
- AN Fitting and swivel for fuel return line
- Certified fuel line clamps
- Bosch 1 to 1 ratio Fuel Pressure Regulator
- Drop-In fuel tank canister with Walbro 255lph pump (complete drop in - no modification necessary)
Absolute Pro-formance
410-526-DRAG(3724)
sales (at) absolutepro-formance (dot) com
1 - 1 of 1 Posts
