Okay, so i have the car in my sig w/ rota slipstreams. I have very tight clearance between the rim and the caliper(I can stick my pinkie in a little) but i want to upgrade my brakes/calipers/lines. Am I stuck with stock calipers w/ these rims? what type of options are there besides getting new rims, because i <3 these
Fogey
Sounds like you bought wheels with a offset of something like 42 or 45. Your best bet is to get some hubcentric spacers. You will probably need 5mm or 10mm depending on what you plan on upgrading your calipers to. With 5mm you may be able to get away with the stock studs. With 10mm it may need some longer studs.
