1 - 18 of 18 Posts
Endless USA S13 Silvia
okay so i've never been drag racing before.......i only got one run in b/c they were doing eliminations and i wasn't going to wait for an hour and a half just to get one run in and wait for another hour and a half......i'm going to try and go to a track on a weekday so i can get more runs in......but i'm pleased with my 60" times......being my first time i hit the rev limiter in first, third, and fourth........when i go next time on a weekday i should be able to dip into the 2.1 60"s:D......i'm please for my first time ever and i'll definitely be able to get into the 14.4s when i can get some more runs in...here's my timeslip
Late,
Daniel
CarDomain da best :)
BTW- Yea a few weeks ago was my first time now I'm hooked.
.012 R/T :eek: That guy must be a regular at the track....you had a good R/T too man.
good 60' .. what are your tires, and mods you're running? gluck with 14.4 .. You'll need a higher trap for that I think. ~96ish
"waah waah waah, I don't dragrace."
Welcome to the darkside, wuss. ;)
I was running 14.8's without the mm's and ks done. you suck!
btw, you're going down at autox tomorrow.
El Burro
Which track did you go to?
I know atco has those eliminations on weekends, I'm not ure if e-town has them too. If you're interested I'm heading to the track this friday, aug 13, with a bunch of guys from my school. I'm hoping the weather is going to be good.
i believe these are his current mods from his PI motorsports member bios:
AIM Cold Air Intake
Hotshot Header
custom 2.25 inch catback exhaust w/gutted cat
Magnaflow muffler
JimWolf Technology clutch
JimWolf Technology lightened flywheel
Advanced timing by 2 degrees
Volk GramLights 57Pro Gunmetal 17x7 w/40mm offset
Goodyear Eagle F1 GS-D3 215/45/17
JIC FLT-A2 with 6k rear spring rates
Nismo rear sway bar
Brembo cross drilled and slotted front and rear rotors
EBC RedStuff front pads
you have all those mods and only hit a 14.8? HOLY ****STICK....i'm going to be changing engines or something.....come on guys...our engine has to be able to produce 300 HP N/A its a 2.5L we can do it
you have the qr confused with the k20, heh
1 - 18 of 18 Posts
