Will putting an aftermarket headunit in the 180 watt system cause the amp and subwoofer not to work? I've read posts here that seem to elude to that, what is the real story? Thanks. :)
i not exactly sure but i beleive that as long as you have you power and stuff still running to the casing you should be fine. now dont quote me on that though hope i helped
Bow to your SE GOD
Buy a proper wiring harness for the new deck, and you'll be fine. It will keep you from 1) guessing what wire does what, and 2) screwing/cutting anything up that you'll need later.
good call thats what i thought
