1 - 20 of 59 Posts
So I was reading in some older posts, that many people beleive the 10 "magical" HP the spec has over the base Se-R is in the ECU tuning, and probably from the intake.
That being the case, couldn't you swap out the ECU's of an Se-R and a Spec and dyno before/after?
Figure you'd give the new ecu's time to relearn their new car?
If one of you dyno mongers could do that maybe it'd be kinda neat?
-Jason
Theory freak learning...
Get your ignition timing advanced on your SE-R and put 91 octane in it, much more easy and will be closed to the Spec... (including the stock airbox removal too for a CAI, POP, etc...)
here's my running theory...
ECU tuning is the reason the spec has 10 more crank HP than the SE-R.
The spec has a HLSD, which accounts for a greater driveline loss, and eats up the extra 10 hp (give or take)
thus, SER and spec have equal wheel HP
NISMOnkey
bean - I want some of what you're smoking, buddy. Stock dyno charts prove that wheel horsepower between the two isn't the same.
-Jason
Because one is a 5-spd and the other is a 6-spd, I don't think the ecu's can do both tranny's
i figured i might as well put my 2 cents in. I have a 2003 5-spd se-r and i raced my buddys 2003 spec-v, i won,okay fine maybe it was just luck,so i raced again and again.. i won. interesting. then about a week later i raced another one of my buddys spec's this one is a 2002 spec-v and same thing but this time we raced three times. my conclusion was my freinds dont know how to drive. so i did what i always do on weekends and went up to the pike,found a 2003 spec-v i had no idea who he is a went for a run and again won. (all cars raced were stock) so i belive either the spec does not have extra 10 h.p or the combination of slightly lighter car and smaller wheels made the diffrence.
2002 Spec-V have differents gear ratio that could explain this also...
I'm Slushie Biotch!!
10hp = bs!!! they claim it comes from higher flow exahaust, the exhaust is identical...end of story, its a lie...a big FAT lie...can we get some stock air box pics, i wanna see the difference...
but u know what it would mean if the spec airbox was 10hp better then the SE-R airbox?...it means that if you put an intake on a spec and it gains AEM/Nismo's claimed 8.7whp that if u put it on a base SE-R it would amount to 8.7whp plus 10 extra bhp for a total of 16.7whp (assuming 20% driveline loss) in other words...its BS...
my theory:
if u put 87 octane in an SE-R and 93 in a spec V the spec v will have more power because the knock sensor will retard the timing on the base SE-R thus giving the spec V extra power, however, if u run 93 in both they will be the same...makes just as much sense as any of these other lame theories :-D
Dude the Automagic trans eats up way more horse than the HLSD ever thought about Spec V's about 144whp and SER's about 130whp.
err.. i dynoed at 140.8 with intake and pulley..thats better then some specs...now if i am at 130 stock, then a CAI really does free up 8-9whp or so
but you know what it would mean if the spec airbox was 10hp better then the SE-R airbox?...it means that if you put an intake on a spec and it gains AEM/Nismo's claimed 8.7whp that if you put it on a base SE-R it would amount to 8.7whp plus 10 extra bhp for a total of 16.7whp (assuming 20% driveline loss) in other words...its BS...
my theory:
if you put 87 octane in an SE-R and 93 in a spec V the spec v will have more power because the knock sensor will retard the timing on the base SE-R thus giving the spec V extra power, however, if you run 93 in both they will be the same...makes just as much sense as any of these other lame theories :-D
the extra 10hp comes from ecu tuning. the base se-r is set at -2 and the spec-v at -1 for base timing.
btw i have never lost to a stock se-r modded or not.
Such a common misconception, a limited slip differential will NOT contribute to drivetrain loss, especially a Helical design such as the one in our Specs
BodeB15 said:
It's a joke new guy...:p:D:)
hes not that new........anywho I thought I had seen this before but the stock air box on the spec is slightly different then on the se-r. http://www.b15sentra.net/forums/showthread.php?s=&threadid=41831&highlight=stock+and+air+and+box
I am sure I could find more info if i searched more. So this coupled with the timing advance and possible a slight difference in exhuast diameter(i think I read that before ill search though). While none of that really matters if you get a new cai and exhaust and timing advance I think they tried to make the spec a little more aggressive but I don't know how well it worked :) .
1 - 20 of 59 Posts
