Hello, I recently bought my 05 1.8s sentra with 151,000 miles on it and have since done general maintenance (oil, transmission fluid, spark plugs, air filters) and now have 156,260 miles.
It runs fine at other gears but when I’m going from 0mph to 15mph, it shifts from 1st to 2nd at around 2500rpm or 3rpm and gives a noticeable jerk at times. It once even reached 3500rpm to shift.
Could that be a sign of the transmission slipping?
Things to note: I have a P0420 code, a torn cv axle boot, and the wheel/tire size is an inch smaller in diameter than stock (bought it that way) seems to idle rough in drive and reverse but not in park or neutral.
Thank you all for your time and wisdom
