i tried to take off my grill to get started on the ghetto grille, but i had two problems, first the lower black thnigs that hold the stock grill in place will not come off, and then when i tried to put the grill on the black things won't go back in!!!!!!!!!!
Not your parent(s)
patience grasshoppa
those little plastic rivet thigs are very tempermental. sepaprate the bottom anchor from the top rivet. gently push the anchor thru and then push the plastic rivet through.
to remove them, take a flathead screwdriver and pop the plastic rivet up. then pull the whole black thing out. (anchor and rivet) just be gentle, their only plastic.
