So here I thought I was getting myself into a quick repair...
Car was having trouble starting, then Friday afternoon on my way home from work, the RPMs just drop to zero and gas pedal does nothing. I scanned the code and pulled a P0335.
So I pick up the crankshaft position sensor for $30 and figure it'll be a quick and easy install. 2 hours later -- I can't get the damn thing to come out! :mad: Screw came out no problem, it rotates, but it just won't come out.
Is there something I'm missing? Tips, tricks? :confused:
Engine is a 2004 1.8L Auto.
theres an o-ring on the sensor meaning it has to be pulled out with equal pressure on all sides. it's a ***** because of its location, but mine came lose with a lot of pulling and a flathead under where the screw goes to help.
@mike049: Yeah, I tried that, but no go.
I took the day off from work to get this done. I'm just going to go at it like this guy:
It's a lot of work to replace a sensor, but I can't get the leverage I need on it, both from bottom or top, without removing more parts to gain access.
Discussion Starter · #4 · (Edited)
Well that finally got taken care of! Before disassembling my engine in a fit of Hulk rage, I decided to try one more go at prying it out within the small workspace available to me from under the vehicle. Great Success! I just about threw the damn thing down the street... :mad:
I replaced the sensor, reconnected any cables and the battery, and reattached the air intake. Started up no problem. I cleared the SES code and drove around the block, no problems. Parked it for 10 mins, then started it up to drive it and get it washed; argh! my overdrive light flashed. I made it there and back without problems.
I'm going to head out shortly, recheck the cables and all connections, then drive it around a bit, push it hard a little, and see if it throws me any sign. :eek:
I hear a lot of people replace both the crankshaft and camshaft sensors at the same time. I may just pick up the camshaft sensor on my way back and take care of that too.
Update: All good! I did miss connecting one cable/sensor. Purrs like a kitten.
Did you spray it with anything? What tools did you use?
I'm going through the same issue and my forearms are super sore.
Keep the harness connected prior to removal. You can then get a better grip on the connector and you can wiggle it out.
