afaik, most everybody (ok, me and two other people I talked to) that put the OEM fogs in after the fact already had the wires run from the factory...are you sure they aren't there? Check under under the car, behind the bumper cover. They should be taped up there, and the correct wire for the light stalk should be taped out of the way inside of your steering column...
