Okay I have a 2003 Nissan Sentra SER spec V. I was driving at the other day got to a stop light, went to put my car in gear to go as like my clutch won't engage? The wheel bearing on the driver side is bad but the clutch felt really strong so I don't think it could be a pressure plate? Quit soda let out at the top but it was too strong just to go out like that? I'm pretty sure the PNP switch that came unhooked I hooked it back up my cables from my super are working and one of the car is on a jack in first gear you can rip it up in the wheel turns a little bit? I'm trying to fix this problem without taking my transmission out could it be my PNP switch or possibly a retainer clip for the axle? Or what help me out
I had something similar happen on my 2001 SE about 5-months ago. I just had the passenger front wheel bearing changed and the tech forgot to bolt the drive shaft back in properly. After a few days of driving I had gear oil all under the car. It drove fine when backing it out but wouldn’t move forward as it should. The clutch engaged but wheels barely turned.
I have or had a similar prob with my 2002 SpecV, changed the drivers front wheel bearing..big hammer, not fun. When I drove home after purchase I took an offramp, stopped - stuck in neutral...I freaked, clutched revved and got first. Was low on fluid as half shaft at inner seal is leaking, looks that way. Drained gear oil replaced with mercron V. Test drive now..,what you deal still?
