So I was driving about 50 miles today in hot 90 degree weather with the AC on. This includes highway, and streets.
Near the end my clutch pedal stopped being as stiff as it usually is. Once when my clutch line came loose I had this symptom and then the clutch pedal went to the floor shortly thereafter and I lost all the clutch fluid. However this time, it just got soft, but kept working. My clutch fluid level is fine.
I have a stainless steel clutchline as well as a JWT flywheel and clutch (but not the stiffer clutch, the OEM replacement one)
Any ideas why this happened and how to stop it from happeneing again? This is the second time this has happened. First time was when I was bedding in my brake pads
