2002 GXE w/199,200 miles, 18,000 on new clutch.
Clutch pedal sticks upon return so it makes it hard to accelerate from a stop smoothly. It will return from the floor on it's own, but when I release it slowly there's a point near the top of the travel where I can feel it stick.
Any ideas? Hopefully it's not internal to the transmission. The clutch job is just barely out of warranty...
Something simple like a return sping? Does it have a return spring or are the springs internal to the transmission the return springs?
Thanks for any advice...
there is a spring on the clutch pedal itself. you should also consider why your pedal is not returning, maybe you should change/flush the fluid, maybe even rebleed it, hopefully your fluid isnt poop brown.
