Spec V 2002.
Here's an initial draft (reference material from www.nissanperformancemag.com). I will update it later.
I messed up my install when I used a regular Torx socket.
DIY people, make sure you use Snap-On Torx Plus to remove your flywheel bolts.
1) Spec V 2002-2003 Torx Plus 50
2) Spec V 2004-2006 Torx Plus 55
Clutch Flywheel Install in PDF
