My OEM clutch is finally done and needs to be changed. Friends and I are going to be doing it and I was wondering if there were any special tools needed for anything, or anything goofy to watch out for? I'm also going to change clutch fluid as well I was going to use Ford dot3 as well.
Any advise out there to make this easier would be great thanks.
coming soon
use GL4 fluid only. GL5 will eat the snychros.
have a tranny jack! Get that car as high as you can!!!
or...PAY someone to do it!! believe me. I have a NICE cut on my arm from installing a clutch......fwd clutch installs SUCK!
ya I was going to but I'm moving and need to save as much as I can. $500 and extra if I need to get the flywheel machined.
I was just changing the fluid in the clutch cylinder. I use dino fluid for that.
also if you have to get the flywheel cut, do it through napa unless you have some connections, they are the fastest i know of...
