I took my car to get my front winter tires mounted and balanced and when I left I noticed the car pulls left when I accelerate. I am extremely annoyed and can't take it back til Monday. I have taken the front tires off countless times myself with no problem. Could them doing a bad job balancing the front tires cause this? :confused:
yea, if it were balancing, you would feel the wheel hopping, especially when over 60+mph. if its the front tires off balance, you would feel it in the steering wheel. if you dont feel any vibrations, either your alignment is out or your tire pressure is uneven. double check your tire pressure on your left front wheel, it maybe lower. if you have a spec this is most likely your problem, the lsd is pulling the wheels evenly, assuming it was fine before you brought it in for snow tracks.
