My car is in limp mode and keeps throwing camshaft position sensor. Won’t rev above 2000, I keep clearing the codes but they are coming back. I replaced the cam&crank position sensors, and the vvt valve. If anything it’s worse now, comes on all the time. Anything else that could cause this? Bad wiring harness?
This happened to me but it was the break switch on the break pedal. It broke off forcing the car into limp mode and wouldn't rev pass 3k. 02 ser
Super Moderator
A member here found the above solution. Might work for you as well.
